Home > Puma (Tdci) > Learning to change gear again
ZeDefender
Rather trivial, but still...
Due to gearbox "issues" (I'm not going to whine any more) and upon advice, I have learned to "granny shift" i.e. clutch in and drop rpm down to idle with every change. If I have to, I will do this until the Defender or I die Neutral
Is this the way one should treat all Defenders anyway?
Cheers,
Matt Tell someone you love them today because life is short.
Post #91930 29th Sep 2011 4:10pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Does this sort of gear change need even for the newly modified clutch?
Post #91932 29th Sep 2011 4:18pm
ZeDefender
Mine is MY11 so I guess it's got the newer clutch but it still clanks! Changing gear really carefully makes everything much quieter though and stops 3rd gear kicking/snatching.
I was hoping others could confirm I am not alone... Tell someone you love them today because life is short.
Post #91934 29th Sep 2011 4:51pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
I tend to ride the clutch a little when changing 1st to 2nd and 2nd to 3rd which stops the clunks on mine. 130 crew cab
98 V8 Disco
Post #91945 29th Sep 2011 5:38pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Sometimes mine will go through the gears perfectly, no clunks, other times it will clunk like an absolute bitch. Sometimes changing gear slowly will still make it clunk... Othertimes I can hoof it away from a junction and it'll be perfect.
It's been back many times and various parts have been changed, but still not much difference. Only 8 months of warranty left too... Rolling Eyes
Post #91987 29th Sep 2011 6:48pm
BigMike
Just match your revs to the gearchage. no clunk, no granny. job done.
Post #92006 29th Sep 2011 8:01pm
ZeDefender
I seem to do that sometimes but when I fail it isn't pleasant Sad
Any advice on how many revs for which change?
(sorry if that's a stupid question Whistle )
Cheers Tell someone you love them today because life is short.
Post #92018 29th Sep 2011 8:16pm
BigMike
You can't really think of it like that. Depends on how much load is on the engine at the time. Try driving along the flat in first, accelerate a bit then come off the gas and feel the lever and put some downward pressure on it. You will find that at a creation point it will slip easily into neutral. Kelp the pressure on it and it will click into second easily - don't use the clutch at all. You can do this in every gear, and on the way down if you use the revs to match the box. It's easier going up though.
Once you get the hang of that just drive normally using the clutch though use it at that point where the revs and box are matched, you'll just get a feel for it
Post #92027 29th Sep 2011 8:44pm
ZeDefender
Thanks
I guess some practice will be required Thumbs Up
Post #92039 29th Sep 2011 9:21pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
that's the way i drive it as well. often don't use the clutch unless moving away from staionary. Just a soft and gentle action and it slips straight in. BM52
Post #92041 29th Sep 2011 9:27pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Don't rush the gear change and try and match the speed and rpm. When speed and rpm match clutch isn't required for gear change. That said I find this easier with the 300tdi, as I think drive by wire and electronics make smooth gear changes in the Puma more difficult.
Post #92052 29th Sep 2011 11:31pm
Happyoldgit
I agree with the others, it's possible to feel your way into gearchanges without using the clutch at all but it takes time and a certain amount of sympathy. The nature of the drive-line means there's quite a bit of slack in the system anyway, these are not euroboxes so whacking up and down the box racing changes will only increase wear and make the clunking worse. Steve.
http://forums.lr4x4.com
Post #92101 30th Sep 2011 12:31pm
ZeDefender
Well, I've been crap at it so far Embarassed So keep trying... Tell someone you love them today because life is short.
Post #92104 30th Sep 2011 1:12pm
warren
It's very satisfying when you get it right... I attempted it for the first time in the Defender earlier today, perfect gear change!
I can sort of feel for a gearchange too using the clutch, (in mine you can anyway, not sure if my clutch is pooched though - I get the clank when I lift off...) although it does seem more difficult to change gear with the clutch than without... Confused
Post #92127 30th Sep 2011 3:58pm
ZeDefender
Okay - seem to have some success speed/gear matching WITH the clutch. Bit more practice/confidence and I might try without... Tell someone you love them today because life is short.
Post #92210 1st Oct 2011 9:35am
