Home > In Car Electronics > Puma 2.4 Defender 110 Keyless Start / Start button
RR08
United Kingdom 2010 Defender 110 Puma 2.4 USW Cairns Blue
Wondering if anyone has converted or experience of fitting a keyless start button in place of the ignition barrel on a defender.
I regularly drive 110 - 2010 year model which has the usual remote to lock and unlock and requires you to insert the key in the ignition and turn it to start.
Got me round to wondering if there is any way to replace the ignition barrel with a start button coupled to the remote keyfob and combine them together? similar to what you see on most modern cars?
Any thoughts or ideas?
Many thanks Terry
Post #958638 17th Jul 2022 4:38pm
htb2
Wales
Still need to sort out the immobiliser and steering lock.
Post #958647 17th Jul 2022 6:04pm
macfrank
Apart from adding another security risk (google kessy theft), it‘s probably the steering lock that would make it impossible. Although a very simple feature for the user, the safety logic behind it is rather complex. You want to make sure it wont lock while driving, ever. I doubt anyone would retrofit it, if at all possible.
Post #958650 17th Jul 2022 6:49pm
