Home > Tdi > 300 tdi Power Loss
pannawonica
Australia
300 tdi Power Loss
A work colleague has a 300 tdi that is suffering from power loss. Can anyone suggest what the common causes maybe. It does not want to go faster than 70 miles per hour. It sounds ok and does not blow black or white smoke.
Post #91585 27th Sep 2011 2:09pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
had a similar problem in my sons 300tdi it was a weak fuel lift pump. they are cheap and easy to replace. BM52
Post #91640 27th Sep 2011 6:28pm
pannawonica
Australia
Thanks I will look into this. Thumbs Up
Post #91715 28th Sep 2011 2:57am
farmer giles
my memory is hazy but i think it was my old 300 which had a split in the head gasket that caused intermitant power loss.
Post #93121 7th Oct 2011 11:57am
Without any unusual smoking, I'd vote for the lift pump too. Darren
Post #93130 7th Oct 2011 12:44pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
i would go down the road of cleaning out the intercooler and intake manafold as this is one thing that can and will strangle the power of a tdi
Post #93829 12th Oct 2011 8:52am
mymini007
1986 Defender 90 200 Tdi HT Java Black
Are all the IC hoses connected correctly, If you have a boost leak this will cause a lack of power too, with no obvious side effects You cant polish a turd!
But you can roll it in glitter Smile
2006 Mercedes Benz CDI320
2001 Volkswagon Caddy Van 1.9 SDi
1993 Nissan Patrol 4.2 TD
1986 90 200tdi - SOLD
1990 Mini mayfair (highly modified) - FOR SALE
Post #130896 12th Mar 2012 10:44pm
