![]() | Home > Wheels & Tyres > Practical ways to put the spare wheel back on the rear door |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello carpetsauce
With no tools, just technique... try this For me the centre security 'stake' acts as a first position manoeuvre, I then regroup and engage with the studs... the 'split-spoke' wheel design actually helps as it is easy to grab around and see through to the 'target'. ![]() Click image to enlarge With a sports injury back picked up in my 20's I am aware of getting this wrong too often... ![]() Good luck SKIP https://www.defender2.net/forum/topic83242.html |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
If you can find one, a Mantec Tufflift makes the task a doddle.
This thread will shed some light. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4254 ![]() ![]() ![]() |
I second that, have a TuffLift and it helps a lot. Flatdog had some on the shelf but not listed online a few years ago, and about the same time I saw a bloke flogging a copy of the TuffLift on a small stall at the LRO show, but I can’t recall the name of the product. 2007 110 TDCi Station Wagon XS
Another vote for the Tuff Lift here. If set up correctly, which admittedly is a bit of a faff, they're a great piece of kit:
![]() Click image to enlarge ![]() Click image to enlarge I've since fitted a wheel carrier to my 110 and it works on that, too: ![]() Click image to enlarge This is a the ex-mil version, which come up on eBay every so often. The civilian version differs in that it doesn't have the large metal bracket that I've drilled and mounted to the top stud. Instead its two mounting straps have fixings to go through holes, which may need a bit of ingenuity to provide, depending on your particular wheel carrier. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
![]() ![]() SKIP https://www.defender2.net/forum/topic83242.html |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 585 ![]() ![]() ![]() |
I think you could make something up like that with a bit of webbing.
I might have a go myself, as the spare wheel is big and heavy. I also find them a bit of a pain when fitting back onto the hub. |
carpetsauce Member Since: 19 Mar 2021 Location: Essex Posts: 58 ![]() ![]() |
Thanks for their replies folks,
Great tips. |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2660 ![]() ![]() ![]() |
To help you getting the wheel back onto the hub (as opposed to the rear door) if you look up Air Wedge Pump Bags on Amazon that might be a solution for you, without the need to carry a shovel to act as a lever. Place the bag by the hub, roll the wheel onto it then hand pump it to raise the tyre to where you can then get it onto the studs then let the bag down. It doesn’t take up much space plus they can be useful for DIY projects as well.. ![]() |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2231 ![]() ![]() |
The original wolf one https://www.exmoortrim.co.uk/tuff-lift.html but £124 new !!!!!!
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 563 ![]() ![]() ![]() |
Only thing is…
…it looks like a nappy ![]() ![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
