Home > General & Technical (L663) > v8 engine oil
asaf
Israel
v8 engine oil
can some one help with the V8 oil engine type and spec?
thanks
Post #956640 27th Jun 2022 12:34pm
Nuclear Nick
From iGuide:
My dealer supplied me with this:
Post #956657 27th Jun 2022 4:16pm
simonb
For anyone else wondering wtf 'Carbon Neutral Oil' is, I'll save you a google.
"Shell Helix Carbon Neutral engine oils are made from a 99.5% pure base oil by its Pureplus Technology. It is a gas-to-liquid process that converts natural gas into a pure base oil with stronger molecular bonds. It can be used for engines such as modern petrol engines, diesel engines without particulate filters, and gas engines."
Post #956659 27th Jun 2022 5:22pm
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
If it's of any help......
Love the psudo-science here!
Natural gas - methane or propane (rarely butane) feed in stocks are converted via the Fischer–Tropsch process which involves a catalyst to a "hydrocarbon wax" with a carbon chain range of 2 carbons to 7 carbons long, vary the conditions will vary the ouput product. This is then converted to a more useable product by further processing (eg: hydrogenation)
The F-T process is being used for replacement fuels for transport, since if the feedstock is from a non-fossil source then the product while is CO2 producing, it is a non-fossil carbon fuel with similar conbustion properties to the fossil equivelant
Yes it is more pure base stock since it is easier to purify a gas stream than a liquid stream. and the fewer impurities will lead to less interferance between the molecular interaction (dipole, van-der-waals, hydogen, ionic, I would not use the word bond)
Is it "carbon neutral" depends on the the source of the nat. gas, the energy required to perform the F-T process and refining steps. Also consider the transport, packing and rest of the carbon footprint aspects.
Me, I'm a Royal Society of Chemistry Chartered Chemist and Science Council Chartered Scientist with a passion for debunking Whistle Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #956683 27th Jun 2022 8:12pm
Nuclear Nick
Blimey, the OP only asked what oil to put in a V8!
Post #956708 28th Jun 2022 8:02am
