Home > For Sale & Wanted > [Wanted] Storage box for rear load area |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 787 |
Weekend bump BORG - Bucks & Oxon 4x4 Response Group
25th Jun 2022 5:17pm |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
Have you looked for ammo boxes, they come in lots of sizes.
25th Jun 2022 5:58pm |
Bradders130 Member Since: 27 Nov 2021 Location: Southampton Posts: 83 |
Do you get anywhere with this? I have something, but it may be a bit big for what you want. |
29th Jun 2022 7:49am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3760 |
This is strangely like what I'm after only I can go 60cm wide...
So far I'm found the closest are old flight cases, the amo box's don't seem that high (at least not the ones I have found). Also my mate bought some van tool box from amazon but I can not longer find them as they were metal and quite cheap. |
29th Jun 2022 8:17am |
Is this any good to you?
Dimensions are 1000mm long x 400 wide x 550 tall Click image to enlarge |
29th Jun 2022 8:53am |
Thanks for the offer of the box above. Unfortunately it is too long. It needs to be around 50cm long as I intend to bolt it to the tub wheel arch and anything longer means I will need to remove one of the side facing seats. BORG - Bucks & Oxon 4x4 Response Group
29th Jun 2022 11:31am |
I haven't been able to find any ammo boxes which are anywhere near tall enough. I have seen some metal storage boxes intended to be bolted to trailers to carry ratchet straps etc but these are a couple of hundred pounds. BORG - Bucks & Oxon 4x4 Response Group |
29th Jun 2022 11:33am |
No worries. I hope you find something.
29th Jun 2022 12:36pm |
This type of thing any good?
https://www.ebay.co.uk/itm/265403700330?ha...SwPuBhj699 |
29th Jun 2022 1:43pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1848 |
There was a company - barebox - did wheel arch mounted boxes and cubby boxes. I know they stopped that, but I have one of their rear boxes which I do intend to sell at some stage.
I’m afraid it’s on top of the shelves in the garage right now, so I wouldn’t be able to get dimensions till tomorrow evening, but looking at your needs it wouldn’t be far off. I’ll take pics and measurements and post tomorrow if you’re still needing something. (edit - might be a bit too long on 2nd thoughts, but I’ll measure it up anyway.) Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
29th Jun 2022 10:43pm |
Thanks, but unfortunately too wide to fit on the tub wheel arch. BORG - Bucks & Oxon 4x4 Response Group |
30th Jun 2022 6:03am |
30th Jun 2022 6:04am |
Here we go then, see what you think. If it’s any use I can consider a price and postage.
Click image to enlarge Click image to enlarge Click image to enlarge Edit - photos got compressed via email. If it’s not readable, it’s 81cm long / 28cm high / 34.5cm wide(deep). I do have the keys for the locks. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
30th Jun 2022 7:41pm |
Thanks for the offer, the box looks great, but unfortunately would require me to remove the side facing seat so will pass on it.
If you are selling, no doubt someone else will snap it up. BORG - Bucks & Oxon 4x4 Response Group |
2nd Jul 2022 6:07pm |
