Home > Puma (Tdci) > Occasional Catching Clutch
Doodlefish
First drive and only occasionally, my clutch catches 1st to 2nd. Only mild and happens only once and awhile. Clutch fluid okay and no other symptoms.
Have accepted it could be me Rolling Eyes
But if not...what else?
Post #956120 21st Jun 2022 4:37pm
Dinnu
What do you mean by ‘catches’. Is it like you lifted the throttle too early? If so worth checking the pressure switch. It right on the master cylinder. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #956129 21st Jun 2022 7:08pm
Doodlefish
I mean...like ive not fully pressed the clutch. Small crunch. I dont think its me but I cant rule it out. Laughing
Post #956159 21st Jun 2022 9:48pm
LR90XS2011
this is something widely reported in the early puma days
what age and mileage are you at
reducing slack in the drive line will reduce it
changing gear more slowly will also reduce it
there is a mod to fit additional locators in the gear selector making it better
if your clutch is on the way out it can cause it
clutch adjustment can be the cause (not fully clearing)
thick carpets / mats can cause not fully clearing
mine did it when new but fixing the above issues it now changes brilliantly in all gears
a lot of drivers have found the 1st gear being so low is often not required, I pull away in 2nd most of the time when on road, probably easier on lighter 90s DEFENDER 90 TDCI XS,
Post #956171 22nd Jun 2022 5:44am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
The shift quality on my 2015 Defender improved considerably after a gearbox oil change. I also find that the shift quality improves as the gearbox warms up.
As has already been mentioned, most of the time I pull away in 2nd gear. I only use 1st on a slope, fully loaded, trailer etc.
Post #956189 22nd Jun 2022 9:14am
