Home > Tdi > 1995 300Tdi Towbar
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
1995 300Tdi Towbar
After a good try with the search system I’ve been unable to find a topic.
I’m looking to fit a towbar to my 300tdi 90.
I can’t find a kit/don’t really know what I’m looking for.
My guess is a Dixon Bate kit won’t fit as they are for later defenders.
Any guidance would be appreciated.
Post #955607 15th Jun 2022 4:56pm
Retroanaconda
Dixon Bate will fit fine so long as you get the correct one. Pre-1998 they’re the same between 90 and 110. After that date they are different because of the 90 rear tank cradles.
This should fit your 90 assuming chassis etc is all standard:
https://www.paddockspares.com/da2121-adjus...-1998.html
Post #955617 15th Jun 2022 5:57pm
Jeebs
I’m really struggling to find a kit suitable. There probably aren’t that many new/used kits out there anymore. Probably been out of production for the best part of 20 years.
Any suggestions?
Post #955620 15th Jun 2022 6:18pm
Retroanaconda
What’s wrong with the one linked above?
They’re still easily available both new and second hand.
Post #955630 15th Jun 2022 7:22pm
Jeebs
Grey on grey on a small iPhone screen….that’s what! I didn’t even see that!
Thanks.
Post #955639 15th Jun 2022 8:07pm
Piggy501
Scotland 1996 Defender 90 300 Tdi PU Arrow Red
Bit of thread drift but does anybody know of a fixed setup for a Tdi 90, or if anybody has modified a TD5 onwards setup to fit? The current Dixon Bate on mine has more wear in the pins and bores than I'm comfortable. I'm wondering if the chassis to drop plate arms from the Tdi setup would neatly tie in to the fixed TD5 drop plate.
Post #955702 16th Jun 2022 7:50pm
Retroanaconda
There was a factory fixed option pre-Td5 as well, which looked like this:
Post #955708 16th Jun 2022 8:58pm
Mo Murphy
Someone only did half a job painting that James ! 😉
50 Shades of Pennine Grey
Post #955714 17th Jun 2022 5:32am
