Home > Td5 > Removing clutch pedal box from Def Td5 with air conditioning
PeteCrenshaw
Australia 2006 Defender 110 2.5 TD XS CSW Chawton White
Need to replace my clutch master cylinder since it's been leaking onto the floor mat for quite a while. The biggest headache seems to be removing the pedal box. Has anyone achieved this on a RHD Td5 with air conditioning?
There is an annoying sill/panel/tab that hooks in the sound insulating trim. I'm not really sure how I'm supposed to remove it since there is the air con unit right in front of the 4 screws that hold it in place. I've attached a photo of one without the air con...
Would I need to remove the whole air conditioning assembly to get at these? And how involved is that? Or can the air con just be slightly moved out of the way without discharging it?
Post #955356 13th Jun 2022 2:32pm
PeteCrenshaw
This tab also definitely needs to be removed, since it obscures the top two bolts of the pedal box.
Post #955357 13th Jun 2022 2:33pm
Hufflepuff
Yes I did it a couple of years ago. My memory is a bit hazy on how I did it - I have a vague memory of undoing the air-con outlet unit bolts on the right hand side and bending it down a bit to give the required access. I certainly did not discharge the air con loop to do it. 2005 Td5 90 XS
1989 V8 110 CSW
Post #955361 13th Jun 2022 2:48pm
PeteCrenshaw
Thanks mate Very Happy I'll give that a go then! I also noticed I can get to the most obscured screw by taking out the speaker in the aircon.
Post #955364 13th Jun 2022 2:51pm
landy andy
Done it a couple of months ago without removing the AC ratchet spanner and loads of foul language.
Post #955394 13th Jun 2022 8:36pm
