Home > Puma (Tdci) > Water Ingress Sheet |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
27th Jan 2009 12:35pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
they can leak via the hinge gasket 2.4 90 XS
27th Jan 2009 12:59pm |
28th Jan 2009 11:14am |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 |
Mine leaks in the rear footwell, someone can't drill holes at the factory and it gets in through the oval hole!
Maybe with the cash us Taxpayers are giving LR they could teach their employees a few skills. |
28th Jan 2009 12:19pm |
dm,do you mean poor fitting door seal ?,I was told awhile back that a door seal from a series LR is a better fit, or you could try packing the seal were it fits to body with bluetack or bodycorking. 2.4 90 XS
28th Jan 2009 12:26pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Both mine leaked.
back to dealer changed both. on inspection they have put silicon on them to hold both them in seems to work no more leaks. but for how long, who knows. NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
28th Jan 2009 2:01pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Some things never change. Is nice to see that almost all of us had a water ingress problems in one or another part of ourPumas.
I had some water ingress in the passenger side and has been repaired at the end of the winter (rainy season here). So I will see in May-June if really works. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
28th Jan 2009 2:09pm |
Yes the door seal is poor fitting (loose) across the top of the door. It's a press fit, so I'm going to first try squeezing the seal's sides together and see if that fixes it. If not I'll talk to the dealer and see what they recommend (maybe sikaflex it on). Can't get to a dealer (nearest is 1100km) at present as the track out of town will be impassable for the next few months. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
28th Jan 2009 9:15pm |
