![]() | Home > Faults & Fixes (L663) > Sound only from front passenger speaker? |
tooslo964 Member Since: 25 Jun 2020 Location: Aberaeron Posts: 42 ![]() ![]() |
You're not alone
Faults & Fixes (L663) > No Audio from Righthand side of Vehicle https://www.defender2.net/forum/topic83333...%20Vehicle Mine went away over night |
D50 Member Since: 08 Apr 2021 Location: Dublin Posts: 20 ![]() ![]() |
Thank for this! I didnt see that other thread.
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
I have found that You will need to lower the car to access height, double lock it and leave for more than 10 minutes for all the other electronics to go into sleep mode / full shut down. It’s a problem with the boot up on start process, my 2015 RRS and 2010 FFRR occasionally used to suffer a similar incorrect boot up process. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
This worked, thank you Tim!
