Home > Td5 > Why won’t fuel pump go in easy? |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
Put the rubber gasket in first, then the pump. Make sure it’s lined up up (take note of locator at 6 o’clock as you’re standing at rear) then push down.
21st May 2022 3:53pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1764 |
When I did mine it felt like an unreasonable amount of force too, especially as you have to get it partially threaded before it won't just ping off on you (Mind you my locking ring is also in need of replacement)
I ended up using a hammer handle on the pump and leaning on the hammer head with my chest to have both hands available to tighten up the ring. |
21st May 2022 10:35pm |
Jobo Member Since: 21 May 2022 Location: Perth Posts: 2 |
Exactly what I ended up doing with the hammer. Should really have got a new ring when I bought the pump. There was also a plastic white ring attached to the black metal ring which I can’t see on the bay pics. It was rotted onto the ring so I didn’t try forcing it as the ring was on last legs but I take it it should be separate from the ring in an ideal world. Well the pumps in, a spare ordered as I went cheap and a new ring in the post. It’s just a real pain that Land Rover puts a strengthener just too close under the load bay. At leat the AA towed me home when the pump quit but the a tech didn’t have a clue, didn’t check pump relay output and just put it down as a wiring fault.
22nd May 2022 4:37pm |
