Home > Tdi > Coolant for TDI 200 Engine
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Hi, currently I am using only tap water for my TDI 200 engine as previous owner only use tap water, so my mechanical not dare to use the coolant as he said don't know what are those chemicals inside the coolant, that might damage the related parts.
some said they only use distilled water without any coolant also quite good. I am decided to use a coolant now, I am understand that a traditional green colour is the most suitable for old engine, so my question is what about this PRESTONE COMMAND HEAVY DUTY NITRITE FREE (Yellow colour)? Is this suit our TDI 200 engine? Or any other recommendations by you guys? Thank you.
Post #952735 17th May 2022 2:09am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
I wouldn't want to see the corrosion damage inside your engine.
Antifreeze isn't just a antifreeze it's also a corrosion inhibitor.
I use Castrol Radicool.
Post #952753 17th May 2022 10:25am
cykoh85
Dear jfh
Ya, you are right! that's why I am decided to use a coolant now.
Anyway, thanks for you recommendation! [/quote]
Post #952774 17th May 2022 2:25pm
Dinnu
My old Hynes manual that covers up to 300tdi states “Ethylene glycol-based antifreeze”.
Most of the modern coolants are OAT and whatever abbreviations they may put in.. just keep in mind not all aluminium alloys are equal so what might work for a Japanese motors might not be good for a European one. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #952787 17th May 2022 4:20pm
spudfan
Ireland
I am using this Mannol Antifreeze AG11
"Concentrated antifreeze based on mineral inhibitors – IAT (Inorganic Acid Technology). Antifreeze intended for a year-round use in any modern cooling system for which the use of ethylene-glycol-based antifreeze is recommended."
https://www.mannol.de/products/operating-a...1-longterm 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #952826 17th May 2022 11:03pm
cykoh85
Thanks Dinnu! Ok, I will check the ingredients before purchase it. Very Happy
Post #952843 18th May 2022 8:05am
cykoh85
Thanks spudfan! I will check it out Very Happy
Post #952844 18th May 2022 8:06am
