Home > Off Topic > So you have a mobile phone..
spudfan
Ireland
Bet this never crossed your mind...
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #952459 13th May 2022 10:46am
Ecco
Malaysia 2014 Defender 110 Puma 2.2 DCPU Galway Green
..i have doubts regarding relativity calculations..i did quite a lot of gps designs and firmware related to it, mostly oil and gas (oil platforms) as well as military grade stuff for navy..what exact relativity calculations/corrections, are to be made on CPU side, im not really sure about..what i can confirm is that, in order to attain accuracy levels on the order of 1 to 10 meters, differential correction is essential (unless relativity calculation is new term for differential calculation). Real time DGPS happens when the base station calculates and broadcasts corrections for each satellite as soon as it receives data. Correction is received by the roving receiver via radio signal if the source is land based or via satellite signal if it is satellite based and applied to the position it is currently calculating. Finally, the position displayed and logged to the data file of the roving GPS receiver is a differentially corrected position, which is pretty much standard math, nothing fancy...or im missing something Snigger
Post #952653 16th May 2022 6:26am
Honeyman
Netherlands 2011 Defender 130 Puma 2.4 HCPU Sumatra Black
The “relativity calculations” (among many others such at atmospheric corrections) are done by the controlling GNSS network (GPS/Galileo etc) to provide the predicted spacecraft ephemeris data (“where I am going to be at what time”) and time offset corrections to be broadcast to, and applied by, the receivers as part of the “navigation message”. Worked on Galileo until Brexit made me “an agent of a potential hostile power” Wink 2011MY 130 HCPU: daily driver
1979MY RRC 2-door: on the drive, in the garage & in a shed - all at the same time.
Post #952665 16th May 2022 9:14am
Ecco
..yes..but that initial article say that 'relativity calculations' has been done on 'computer chips on your cell phone' which im not so sure about, hence my previous post..and those 'relativity calculations' that you have described are literally differential offsets, nothing related to 'relativity'..
Post #952667 16th May 2022 9:23am
Honeyman
Sorry if it didn’t come across well, but I was intending to agree with you! 2011MY 130 HCPU: daily driver
Post #952669 16th May 2022 9:27am
macfrank
It was a topic at school long before mobile phones were available for "normal people" Smile
The bottom line was, IIRC, that GPS wasn't possible without relativity because the satellite's clocks move at a speed where relativistic effects can't be neglegted.
However, I also think this "wohoo! you're phone caclulates Einstein's equations!" seems to be one of those journalistic simplifications that turn out wrong.
https://en.wikipedia.org/wiki/Error_analys...Relativity
I understand the need to simplify things to get it across to "the public". But, sadly, it often leads to all kinds of misunderstandings of how things really work. And in the end someone suggests to inject disinfectants to get rid of a virus... Rolling Eyes
Post #952832 18th May 2022 6:14am
Honeyman
Absolutely! It’s a shame, because the navigation chipset in a mobile phone is indeed doing some really cool stuff in order to derive a position fix: the received signals are insanely weak and the amount of real estate available in a modern phone is somewhat limited. 2011MY 130 HCPU: daily driver
Post #952839 18th May 2022 7:23am
