Home > Puma (Tdci) > Third gear paranoia
ZeDefender
Third gear paranoia
Anyone else find third gear particularly "clunky/clicky" to engage? Is it "normal" after 5000 miles?
Mine just got worse after going to dealers for 3rd handbrake "repair" (failed).
Getting paranoid about evil, Censored off German mechanics "spitting in the food" on test drives...
Matt
Post #90960 23rd Sep 2011 9:18pm
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Wink
Me,
I've found it since my first defender. It was a 200tdi. The 3th gear have always been rough. Whistle
You have to be soft with your gearbox. She will bring you far.
Thumbs Up
Post #90970 23rd Sep 2011 9:42pm
MK
Normally it is the 2nd gear on the Puma. Maybe a problem in the syncro. You are approaching the state where you`ll want a total replacement from the flywheel back to the Tcase. Puma 110" SW
Post #90992 23rd Sep 2011 10:31pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
My second gear does this most of the time and third gear snatches a little sometimes. A new clutch is in my garage waiting to be fitted. Thumbs Up 130 crew cab
98 V8 Disco
Post #91115 24th Sep 2011 7:09pm
MK
I do not think the grinding will be gone with a new clutch (IMHO) Puma 110" SW
Post #91126 24th Sep 2011 7:52pm
alantd
My 3rd gear is hard to select when cold. Has been since new - now around 25k on the clock.
I just have to take my time for the first couple of changes and then it warms up.
Doubt it's a clutch issue. One that started out as a 2.4 TDCi 110 XS
Post #91447 26th Sep 2011 9:47pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
No problem with mine in 3rd or any gear, but I'm told that I do leave changing till late, thinking about it 3rd gear is for quite a short time, straight into 4th normally.
Is there any corrilation between rpm and roughness? Ours had "bag of hammers" sound at 2300 to 260 rpm cured by emc upgrade under warranty. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #91452 26th Sep 2011 10:02pm
ZeDefender
It's strange - no difference cold or warm, sometimes it happens (or not) at low rpm sometimes high.
It makes it hard to know what to do. I guess I just have to wait to see if it gets worse (or better?)
Trouble is I can't help thinking the Censored of German mechanic knackered the gearbox when he had the car... Sad
Post #91455 26th Sep 2011 10:21pm
fekete
Let the dealer know.... then it is logged.... i had mine changed it took time for the dealer to except it tho...I went in 10 + times for them to acknowledge it good luck Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #91458 26th Sep 2011 10:30pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I called Stratstones today to bookmine in for its 4th gearbox / clutch inspection / replacement episode... The numpty I spoke to claimed that they (Stratstones, main Land Rover dealer) had NEVER heard of any Puma gearbox / clutch problems...
Second is a real pig to engage unless I go reallllly slow with the change, third just grinds, and now fourth is starting to get notchy...
I emailed Dave Ashcroft a couple of weeks back, and he seems to think the root cause is a dragging clutch and or synchro issue... The Land Rover "service people" I have chatted with seem to think nowt is wrong.. Err, sorry to dissappoint chaps, but summat is fukt, and I want it sorting...
Is there a different gearbox that will fit the Puma? ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #91459 26th Sep 2011 10:36pm
fekete
Shax don't take there Censored mate i got mine replaced it took me time but now my g/box is great no stiff or notchy gears at all Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #91463 26th Sep 2011 10:47pm
MacDefender
Brazil 2007 Defender 110 Puma 2.4 CSW Zermatt Silver
As some of you, I have my clutch repleced. The new one is softer then the original. ALL the gears seems to engage more easy (for a Defender)...no more paranoia.... Thumbs Up
Post #92285 2nd Oct 2011 2:42am
ZeDefender
Sounds interesting! What year is your Puma? Do you know if it had the old clutch design? Were there any other clutch symptoms?
Thanks,
Matt Tell someone you love them today because life is short.
Post #92289 2nd Oct 2011 7:41am
MacDefender
My old clutch died in the middle of the road. Defender full of load plus a ATV in the back.
I was going to the beach for a 7 days vacation....really nice.
I tried to fit a Ford Transit clutch without success. After 10 long days my new clutch was installed and the gears automatically improved their engaging behavior.
I dont know how long this clutch will live, but is definitely a different one. Bow down
Post #92441 3rd Oct 2011 6:34pm
ZeDefender
Glad you finally had success Thumbs Up
What model year is yours?
Post #92451 3rd Oct 2011 7:45pm
