Home > Puma (Tdci) > Could this be a Brake switch issue?
nidge n
Hello all,
Gremlins have come to revisit me and this is the present they have left. Each time i press the brakes the interior dash board lights come on. The brake lights work ok. Rather than start searching for an earthing or a shorting issue, i am reaching out to see if anyone has experienced this issue and if the outcome was a faulty brake switch.
Many thanks for your help
Nigel
Post #952248 11th May 2022 11:30am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
How’s the level in the brake reservoir ?
Post #952252 11th May 2022 12:46pm
nidge n
Hi Mark, brake level seems to be ok, settling on the high level line.
Post #952258 11th May 2022 1:52pm
The first thing I would try is disconnecting the harness from the brake light switch and shorting the terminals on the harness-side connector. This would allow you to determine if it is the movement of the pedal grounding something (trapped wire etc) or if it is a short between the brake light circuit and the interior light.
The interior light is a switch-to-ground circuit so it is possible that is it a strange earth fault, and when you press the pedal the brake lights provide a path to earth.
Post #952287 11th May 2022 5:54pm
nidge n
my job for tomorrow, thanks for helping
Post #952308 11th May 2022 8:19pm
Dinnu
Is it the dash illumination or the Interior light that is coming on?
I would check if they are simultaneously coming on together. So either with the help of an assistant, ir park it with the rear against a wall so you can see when the brake lights are on, slowly press the brake pedal until either one comes on.
If they light up simultaneously, then most likely a poor earth that is causing a potential on the illumination/light. If one comes on after the other, then something chafing on the pedal itself. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #952313 11th May 2022 8:57pm
