Home > 130 > Spinning Studs + T-Case Oil Leak !! HELP !! (RESOLVED) |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3471 |
Actually they are not studs, but UNF bolts. One side of the hex head is against the output flange and should hold it from spinning (at least that is the theory).
Better if you replace with exactly same bolts, but to do that you need to remove the output flange. While in the process you may inspect the seal land on the output flange and replace the output oil seal. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
10th May 2022 4:55am |
BajanRover Member Since: 12 Feb 2021 Location: Barbados Posts: 74 |
Dinnu whats up bro!
Ye I just noticed they were bolts instead of studs, I just think its a silly design but it is what it is lol. I will borrow a 30mm socket from a neighbour and get to work. I do believe the seal needs changing because I am seeing oil inside of there, also missing was the metal oil plate thingy that would direct the oil to the exterior of the drum, so since that was missing from the inside, the drum shoes were gunky. I'll update after the madness! |
10th May 2022 1:34pm |
So everything is back up, I changed the output shaft seal as well since there was noticeable oil on the drum shoes and inside of the drum. The metal shield that would direct the leaking oil outside the drum was not there initially. Both the front and rear propshaft UJs were changed as well as new bolts and nuts to hold the shafts in place. Truck feels 100% more solid on the road.... maybe that's because I was driving for a while in diff lock with the front shaft off for a few months now. Dinnu thanks again for your speedy response bro! |
11th May 2022 12:10pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
Every day is a school day… well done Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
11th May 2022 2:42pm |
Couldn't agree with you more Bud....I think we take the internet for granted... you guys are miles and miles away and within minutes all my questions and issues are resolved.
That blows my mind Especially being from the small island of Barbados where Defenders are a rarity it makes my life 10000x better knowing I can source all of my information and advice from you guys! |
11th May 2022 3:13pm |
Good to hear.
I think that plat that you refer to was removed on later transfer boxes (I do not know if all transfer boxes with direct entry cable). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
11th May 2022 3:15pm |
Oh fair enough.
Thanks again bro |
11th May 2022 3:21pm |
