Home > Td5 > Cruise control on a MY2000 Defender td5 with a newer ECU |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Hi my 10p ecu died a while back and I replaced with an NNN.
Fitted cruise control wiring as per all the diagrams online and it works great. Depending on your transfer box ratio you may need a speedo healer if you’re running 1.2. Having a nanocom is handy to check your switches are correct. |
26th Apr 2022 9:54am |
Should work.
You might have to get used to it and think it isn't working at your first try as it is a slow system. The way I do it is keep pushing the accelerate button till you feel it starts pulling. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
26th Apr 2022 6:42pm |
