Home > My Defender > Brick the Utility..
Page 2 of 2 <12
BrickBox
I’m really not sure yet. I’ve got a bit more reading to do. But the old double nut does seem a lot more straight forward and definitively geared towards home DIY’ers. 2008 2.4 110 Utility Station Wagon XS.
Post #989006 14th Apr 2023 8:27pm
BrickBox wrote:
Cheers both Very Happy
It’s certainly a labour of love. The list grows, so does the enjoyment.
I’ve ordered this OEM wheel bearing kit
https://www.ebay.co.uk/itm/374559827409?mk...media=COPY
It’s a little bit OTT and possibly on the expensive side. But I’ve never done a Defender wheel bearing, so I figured having the whole kitchen sink for the first time may help a little.
That actually looks a good kit, and the only thing it lacks is the stub axle which may be needed if one of the bearings has picked up, or if the hub seal land is worn.
Post #989009 14th Apr 2023 8:47pm
BrickBox
Cheers BlackWolf, your input is always appreciated Bow down
This was my next thought. I’ve not stripped the hub down yet. But I do have a potential stub axle change in the back of my mind. Do it all right the first time and then it’ll be right for another 100k. 2008 2.4 110 Utility Station Wagon XS.
Post #989010 14th Apr 2023 8:50pm
landy andy
I swapped all of mine across to double nut. Thumbs Up
Post #989016 14th Apr 2023 9:22pm
BrickBox
Can you give me some insight, please? Andy.
There seems to be some suggestions of changing the stub axle for a fresh one to do the conversion? 2008 2.4 110 Utility Station Wagon XS.
Post #989018 14th Apr 2023 9:32pm
landy andy
There is no swap of stub axle. Just a case of leaving spacer out. Using two washers (one thick, one thin) and two nuts instead of the thick washer, and a stake nut. It’s easier to check and adjust especially road side, and I dislike the use of stake nut on the tread, as it can damage the thread.
Post #989031 15th Apr 2023 9:05am
BrickBox
Nice little upgrade completed today.
Genuine LR single piece HD rear shafts. No idea why the single piece aren’t a standard fit item on the Defender. Can’t believe the difference in tightening up the driveline after fitting these.
Really pleased with the outcome.
Cheers for reading. 2008 2.4 110 Utility Station Wagon XS.
Post #990302 25th Apr 2023 4:09pm
Brickbox wrote:
... Genuine LR single piece HD rear shafts. No idea why the single piece aren’t a standard fit item on the Defender. Can’t believe the difference in tightening up the driveline after fitting these.
They were standard from from chassis GA481822 (2014 or thereabout as I recall) onwards (the time when presumably the warranty costs from customer complaining about backlash outweighed the cost of not doing something about them).
When I bought mine in 2017 they were a blistering £470 or so each and were bizarrely made in South Korea, a country which I don't readily associate with quality engineering.
Post #990318 25th Apr 2023 6:49pm
BrickBox
That’s good insight- thank you. I’m surprised it took them that long to decide against the 2 piece shaft. Proper crap design.
Thankfully I paid near half that, for the pair.. (£220 delivered for the pair, if I remember correctly) 2008 2.4 110 Utility Station Wagon XS.
Post #990329 25th Apr 2023 8:08pm
That's a good price for genuine shafts! May I ask where you got them?
Post #990335 25th Apr 2023 8:45pm
Page 2 of 2 <12
