Home > Technical > Anyone with a Truckman Top? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Evening,
Just picked up a bargain truckman roof for my double cab. I was wondering if someone who has one fitted could answer a couple of questions though please? 1. Does it attach to the tub just with four bolts? There is a hole in each corner which seems to line up nicely with holes in the cappings but the Truckman site shows some plastic clamps which it says should be used to attach it. 2. What should be under the front edge of the top? The front face sits rearwards of the transverse tub capping so looks like it should have some kind of drain channel. Have tried it with the drain channel section from my soft top but the ends of it are too tall and hold the roof off the capping. Did the truckman top originally come with one? Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
16th Apr 2022 7:59pm |
Great stuff thanks,
Are these the clamps you have: https://www.truckman.co.uk/aerotop23-fixin...dc-zfix765 Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
17th Apr 2022 8:43am |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
Yes Steve.
That’s the ones |
17th Apr 2022 12:31pm |
Cheers 02' 110 TD5 Double Cab Rebuild Thread
17th Apr 2022 3:00pm |
Hey up Steve.
I’ve just picked up the rain Chanel For the top. My friend says it helps but doesn’t make totally water tight. |
26th Apr 2022 6:03pm |
