Home > General & Technical (L663) > Defender 90 Commercial Rear Windows Unblock
Farmeriain
Sorry if its been covered before (I have looked!)
Has anyone managed to uncover the rear windows in a 90 variant, to make it possible to see through them?
Looks like there is a plastic trim on the outside which should just pull off, and an internal trim which unbolts.
But is the glass then see through, or is it etched black?
Post #949269 13th Apr 2022 2:11pm
lightning
So in the Commercial, the glass is actually still there, but is covered up by plastic trim?
Post #949380 14th Apr 2022 5:36pm
Farmeriain
Yes. But it looks like the glass is etched, so removing the plastic won’t be any use.
Just wondering if anyone else has got any further.
Post #949660 17th Apr 2022 5:56pm
General
Just had it done. You need to replace the glass which I ordered from Land Rover.
Part numbers below for the privacy glass version.
LR132088
LR132089
Each cost £267.83 +vat
Looked to be a challenge as they are full of Ariel’s but got them fitted by national windscreens in chesterfield for £144.
Before
After
Post #954341 1st Jun 2022 7:57pm
Farmeriain
Thanks for the reply - really useful photos and part numbers!
Post #954370 2nd Jun 2022 7:24am
General
It took quite a bit of work to get the correct part numbers so thought it was useful to share.
Post #954387 2nd Jun 2022 9:28am
Andy McPandy
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Looks a really worthwhile job. Thumbs Up Thumbs Up
Post #954473 3rd Jun 2022 9:57am
GrouseK9
United States 2016 Defender 110 BMW M52 2.8i Petrol CSW Auto Indus Silver
Well done and great posting details!
Post #956224 22nd Jun 2022 3:23pm
Swac3
Seems like a total waste of money...On Landrovers part that is. Such a pointless uneconomic exercise stocking and installing different glass that's then covered both inside and out only on Commercials.
Had thought about removing the inside trim panel and the stick on outer panels on Ours but dont think i'll bother now. 3 Landrovers
Post #956274 22nd Jun 2022 11:57pm
camelman
Might be something to do with being able to sell it as a commercial vehicle, enabling VAT to be reclaimed and reduced benefit in kind.
Obviously, if you're not running it as a commercial vehicle its a faff.
If they were to produce them with normal windows, they might struggle to argue its a van.
The likelihood of the VAT man wanting to see your 'van' is quite low but if they did then there could be an issue.
Post #956303 23rd Jun 2022 11:04am
Swac3
Aye, thought about it shortly after posting, Maybe a Stick on Exterior panel and the removable interior trim wouldn't comply with the rules. Could have been worse I guess, It might have been a welded in panel. 3 Landrovers
Post #956364 23rd Jun 2022 8:44pm
Farmeriain
So the decision was taken to proceed. I tried two glass installers and both wanted a lot of the trim panels removed to give them good access to the glass (they didn't want to do it themselves!)
Took two and a half hours to work out how it all came apart, and another two hours to put it back together again.
Have left the bulkhead out to improve visibility further.
I think the results were worthwhile.
[/img]
Post #956747 28th Jun 2022 4:10pm
lightning
That looks a worthwhile modification. Can you post a picture of the Land Rover from the outside?
Post #956814 29th Jun 2022 11:46am
General
Here’s what mine looks like from the outside
Post #957585 7th Jul 2022 2:49pm
LR Nuts
these are the panels, if you have a 90 with clear/tints and want to black-out for sleeping.
Post #962411 21st Aug 2022 5:01pm
