Home > In Car Electronics > Puma Windows lift connector pins
Anvil
Italy 2008 Defender 90 Puma 2.4 CSW Tonga Green
Hey all, does anyone know which type of pins are used for the connector C0322 ?
As usual Rolling Eyes the cable broke and I want to change it and not just fix it (as you see the blue cable turned green Very Happy ).
I've been able to disassemble it but I can't find any info on that specific connector/pins.
Pins looks like some delphi or amp (for sure not the ones I already have Sad ) but I'm not really sure they will fit or match the lock system to stay in place.
Any info on the C0326 too ? I've found it on ebay, but maybe it's available from some other (known) shop
TY
Post #948662 8th Apr 2022 5:03pm
geobloke
I think this is the connector and terminals you need - https://www.mobilecentre.co.uk/jlr-2-way-m...-connector
Post #948677 8th Apr 2022 6:02pm
The inserts look very similar to Econoseal ones (as does the seal) but without an indication of the scale it is hard to be sure.
Post #948688 8th Apr 2022 7:07pm
Anvil
Thanks Very Happy
I've spent half a day searching resellers sites and I wasn't able to find anything ... not to mention google
Unfortunately that site only ships overseas orders starting from £150, but at least I have the connector code
Post #948726 8th Apr 2022 10:20pm
Anvil
Yep, they're so similar I thought I could use those I have, but they are a bit smaller than the original.
I need to measure it again as I deleted the file where I noted it Evil or Very Mad
Post #948728 8th Apr 2022 10:24pm
rallysteve
The connector is a Sumitomo HM series but the terminals are universal between the MT/HW and HM series.
The mobile centre link is correct but i would imagine you can find the terminals more locally.
Simtek can also supply: https://www.simtekuk.co.uk/product.php/sum...:::7169176
Alternatively PaulMC (if he is still around) should be able to supply.
C0326 is a harder one to source. Paul is the only source i know:
https://www.ebay.co.uk/itm/YPC500150-Defen...635-2958-0
Cheers,
Post #948731 9th Apr 2022 4:26am
Anvil
Thanks, this is helpful. I'll search it from some local dealer
Yes, me too Smile
Post #948779 9th Apr 2022 1:12pm
