![]() | Home > Td5 > Anti roll bar |
The spacers are super easy to make yourself, literally flat steel or box section sandwiched between the chassis mount and anti roll bar bush. Considering where you live a local mechanic would be able to source the metal and fit.
However on a 2" lift the majority of folks wouldn't necessarily bother to fit the spacers. Although you should to keep the geometry the same. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
I don’t bother with ARB’s.
But these can be used for spacing them down. https://www.westerntowing.co.uk/product/co...gKkyfD_BwE Available in many thickness |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
I got my front spacer blocks from extreme4x4 as they were cheaper than the Terrafirma versions.
They do come with the additional fitting kit. I only have the ARB on the front. |
