Ianh
blackwolf wrote:APK wrote:Ianh wrote:Origiomal battery for the Puma was a varta lfd 90. Superseded by the led95 but still wet battery but with enhanced efb technology. This a leisure /starter battery. A perfect battery for a Puma, and probably a 300 tdi
Thank you
This one?
https://www.varta-automotive.com/en-gb/pro...30-095-085
Does that support the remote vent pipe that the standard LR battery has?
Hi blackwolf, Yes like the original LR Puma battery it has two vents in the same locations as the LR Puma original , just push the vent pipe into the one at the positive terminal end and fit the supplied blanking plug in the one at the negative terminal end. The battery comes from Tayna batteries with vent blanking plugs installed for transit, which must be removed once you take delivery . I put them back for installation then removed again once in place .However Varta include one as well, attached to the plastic positive terminal cover, ready to be detached and used at the negative end. (You can see it in the picture of the battery)
Hi APK. I have the one you linked to, the LED95. However it’s worth noting the Varta LED95 looks to be the exact same as the Varta N95, the former is marketed as a dual purpose leisure battery with 2 year warranty and £134 from Tayna batteries, the latter marketed as a starter battery with a 4 year warranty and £138 from Tayna batteries. However I may be wrong and they may not be exactly the same, so worth checking with Varta. As I said I have the LED95, it’s been in for two weeks and performs very well. I will report on how well it stands the test of time, but as the improved EFB based LFD90 replacement I have high hopes.
Ps this is for the puma’s. It’s a 019 style so you need to check it fits in a 300TDi. I.e size, battery terminal size and orientation, fixing clamps , vent pipe location etc.
5th Apr 2022 7:42pm |
