Home > Modifications & Maintenance (L663) > Warning Flash Module for indicators + auxilairy flashers
Defendit..
Netherlands
New mod in progress...
In some situations it can be handy to increase the visability of you and your car.
Looked at some videos from wicked warnings, they make plug and play harnasses direct to the BCM
So I found a Warning Flash Module for 6 led lights and 20 different flash programms. ( 5A, max 60w)
Did some testing first with the indicator ring in the Nolden 3rd gen 90mm High Beams. 2 x 8w for indicators.
Schedule with the 4 wires from the BCM
Tested the right indicator with a bypass (:Yellow/Violet wire) and some flashing modes.
Now finding the right wires on the connectors of the BCM, 4 relays to isolate power back to the BCM, 2 direct.
Need to make another relay for power, on/off and momentary+ for changing Flash programms.
To be continued.. No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #947844 2nd Apr 2022 11:25pm
