![]() | Home > Technical > Tdci battery tray picture |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2297 ![]() ![]() ![]() |
Hello Rad666
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge This help... ![]() https://www.defender2.net/forum/topic83242.html |
Rad666 Member Since: 21 Jun 2016 Location: North yorkshire Posts: 89 ![]() ![]() ![]() |
Brilliant exactly what i wanted, have you changed to just bolts instead of the long studs?
Bundy Member Since: 21 Sep 2020 Location: Cheshire Posts: 98 ![]() ![]() |
If you need these I've just removed my battery tray and clamps as gone to a twin setup...
Cheers Al |
How much posted?
make me an offer?? I tried to find a second hand one to put 2 side by side and couldn't find any, so not sure what to charge....
pics for you...2 of the captive bolts were removed when I was playing about with it (just means adding a couple of bolts and doing a reacharound to tighten them!)
![]() Click image to enlarge ![]() Click image to enlarge |
Yes... I went from... ![]() Click image to enlarge To... ![]() Click image to enlarge To make (more) space for... ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
Very neat and sooo clean!!
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 878 ![]() ![]() ![]() |
In the first pictures - Is this where the original jack is kept?
I’ve not been under the seats to look myself yet. 2008 2.4 110 Utility Station Wagon XS. |
I only need the bolts and the clamp, not the plate, £15 posted? |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Sooo sooo clean! ![]() |
Seems fair enough. I’ll send you a message. Cheers Al |
