Home > In Car Electronics > 2004 Defender Td5 Towbar connections
deejayen
I've got a factory-fitted towbar with a 7-pin socket. I seem to remember the socket is wired with a short flying lead to a connector on the chassis.
I'm thinking of buying a caravan with a 13-pin connector and 12-volt system. I'm just wondering if my Defender will have the secondary wiring in place, and if so, is there a Land Rover 13-pin socket which will plug in to a chassis-mounted connector?
I suppose another option might be to add a secondary 7-pin socket (if the Defender is pre-wired for it) and then use a 2x7-pin to 13-pin adaptor.
Post #946500 21st Mar 2022 5:08pm
Screbble
Sorry this probably isn’t much help…
The plug/socket is behind the OSR light panel (behind the plastic cover).
I don’t recall seeing any other ‘spare’ plugs or sockets when I changed mine a few years ago.
Here’s the wiring diagram below:
I tried to take a photo of the cable/plug but it didn’t work on the dark Whistle
I suspect you’ll need to provide a fused unswitched positive to achieve your desired outcome Thumbs Up
Post #946913 24th Mar 2022 8:01pm
No, since the 13-pin socket is an amalgamation of the 7N and 7S sockets, it involves about the same amount of installation effort as a 7S if you want it to be fully functional. It isn't plug and play.
The 13-pin socket is also an MOT testable item, the 7-pin sockets are not.
Post #946915 24th Mar 2022 8:16pm
deejayen
Thanks very much!
It sounds like the sort of job for which I'll have to enlist some help!
Post #946990 25th Mar 2022 12:39pm
