Home > In Car Electronics > OEM Sub wiring route? |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
I have a take-off genuine LR Alpine Sub waiting to go into my puma 90. This is on hold until Martin's shop reopens so I can get one of his installation looms. But in the meantime, I'll need to get on with my dynamat and Wright off road matting install.
I noticed from LandRoverAnorak's thread that the factory subwoofer plug comes up through the seatbase https://www.defender2.net/forum/post733726.html#733726 could anyone confirm how the factory subwoofer wiring gets from the head unit to the position in the photo above? I definitely want to copy the factory wiring as far as possible. I don't know whether it drops in front of or behind the bulkhead / over or under the transmission tunnel or if it is just under the carpet and then into the seatbase from within the cab. |
14th Mar 2022 2:26pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 823 |
The std speaker wires all go out to the engine bay from memory then back in later on, or under the car Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
14th Mar 2022 7:36pm |
