Home > Maintenance & Modifications > Monroe Ride Leveler etc
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Hello,
Hope all is well.
(1) May I know if the Monroe Rider Lever came stock with the 300tdi County or was it an add-on?
Also, how does it work? Google and youtube did not have anything for this particular model.
(2) Any idea what the central button does/might do?
Thank you!
Kind Regards
 APK
MY2016 110 Adventure Corris Grey
MY1997 110 County Station Wagon 300 Tdi Alpine White
Post #944935 7th Mar 2022 2:56pm
The ride leveller is definitely an add-on.
The orange button is also non-standard and could be anything, really. Do you have any additional kit like spot lights or work lights? Darren
Post #944936 7th Mar 2022 3:06pm
APK
Nothing I am aware of although I did notice a very small attachment on the b-pillar, will send a pic.
The dealer I purchased it from had no idea either.
May I know what should have been in place instead of the orange button?
Thanks! APK
Post #944938 7th Mar 2022 3:29pm
On earlier models that was the space for the optional clock. When that moved to the dash (200tdi era?), it was just blank. Darren
Post #944941 7th Mar 2022 3:40pm
ibexman
Can you show us the ride leveller units🤔
Post #944951 7th Mar 2022 5:08pm
APK
Thanks APK
Post #945143 9th Mar 2022 10:50am
APK
Sure, did you mean a closeup of the dial? APK
Post #945144 9th Mar 2022 10:50am
ibexman
No the actual shocks on the axles
Post #945145 9th Mar 2022 11:03am
APK
I couldn't find anything different on the axles or the shocks so I showed it to a LR mechanic.
After inspecting he told me that the ride leveler is connected to a compressor under the driver seat and nothing else.
When I press the button on the right, the compressor runs but since its not connected to anything nothing happens. I assume it was being used to top-up tyre pressure at some point?
Apologies for taking so long to get back to you and not being much help... Neutral APK
Post #962752 24th Aug 2022 3:37pm
DefenderGuy
Netherlands
I now this post is from one year ago, but I was wondering if you want to sell the Ride leveler and pump by any change?
Post #1005372 25th Aug 2023 2:21am
