Home > Puma (Tdci) > Disc handbrake |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
Has anyone tried one of these:
www.x-eng.co.uk/X-BrakeDef.asp Is it any good? Does anyone know if it will fit a Puma? Cheers, Matt |
18th Sep 2011 5:03pm |
Lots of people like and get on well with them. Steve.
18th Sep 2011 5:22pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
think it has a different bracket for the PUMA and Ive heard you may have to remove the centre silencer to fit it to a puma, best contact the suppliers/manufacturers DEFENDER 90 TDCI XS,
I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 10th Oct 2011 4:56am. Edited 2 times in total |
18th Sep 2011 5:25pm |
Do you mean permanently or just to fit it |
18th Sep 2011 5:27pm |
was told permanently but as I say best to ask Xeng, alternatively I expect someone will come along and respond whom knows for sure or has one fitted to a PUMA DEFENDER 90 TDCI XS,
I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 18th Sep 2011 5:30pm. Edited 1 time in total |
18th Sep 2011 5:28pm |
Cheers. I will ask X-eng tomorrow but if so, I'll never get that through in Germany
18th Sep 2011 5:30pm |
Yeah but I've got a "slow machine gun" noise when coasting to a halt and the German dealer is pants... Praying its the handbrake... |
18th Sep 2011 5:39pm |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 |
Hang on chap...£200 is a fair amount of money for something you aren't 100% sure will cure it, won't it also affect your warranty?
Have you checked that it isn't you propshaft that isn't making the noise? |
18th Sep 2011 5:48pm |
Good point - I am giving the dealer another chance (I have marked the drum to make sure he really does replace it) and will tell him to check the propshaft as well but if the banging continues the only way to get to the bottom of things is to try the disc. I am hoping it won't affect the warranty on most other parts (don't they have to prove I have caused a fault?) ... still got some budget left anyway - wife wanted a Volvo - yeuch |
18th Sep 2011 7:04pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
Speak to Simon at X Eng. He is extremely helpful and backs his gear. We had a slight problem with some of his kit 3 years after fitting it and giving it some abuse. He replaced the items without quibble, so I think Simon is a good bloke to do business with.
We have his brakes fitted to our Disco and 300 TDi 110. Not so far to our Puma but that is a matter of time. Nicked from his website
Brendan |
18th Sep 2011 7:13pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Mail Si at X Eng,, Have known and dealt with him for 8 years or so, since X-Eng more or less started,
The X brake is a good bit of kit,, do a search on here, will come up a few times, have 3 of them fitted at present to various vehicles, but not done the Puma's as yet,, Tend to agree with Woody thought, you should not have to be spending out, to sort a problem, the dealer should fix,, PS,, Nowt wrong with a proper Volvo Your wife has some taste California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
18th Sep 2011 7:50pm |
Cheers! Spoke to Simon - fantastic bloke - helped me do a calculation of prop speed - 8 revolutions per second at 15 mph - exactly matches banging noise. So problem should be brake drum, prop shaft or transfer box. He suggested taking drum off (and maybe reversing it) and seeing if banging is still there - might do this. Then I can point the dealer in the right direction |
19th Sep 2011 3:40pm |
Yup...
Firstly take rear propshaft off and go for a drive (obviously stick it in diff lock) If noise is still there, then take handbrake drum off. Don't take both off at the same time otherwise you won't be any wiser |
19th Sep 2011 3:44pm |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
HI I have one of the x eng disc brakes fitted to my Td5 and really pleased with it. It is great offroad as it does not get clogged with mud nor is performance affected
20th Sep 2011 10:05pm |
