![]() | Home > Technical > Bulkhead spare wheel mount |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4746 ![]() ![]() |
I have one on an LR 88.If that suits I'll photograph it for you.
You can get a piece of metal bent to go over the bulk head and a long bolt welded to it to fit through the wheel with a nut to hold it. I had one made up for a 90 hard top many years ago. . 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Here are the two versions mentioned above, the factory fitted version on the LR88 and the home made one I used on an LR 90 hard top. On the home made one I put a piece of rubber between the metal"U" and the bulk head. Worked really well.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
