Home > Puma (Tdci) > Windscreen wiper issues...
Trendkill110
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Barolo Black
Hello folks.
So my wipers don't 'Park' which I believe could be the parking switch.
Also, intermittent and normal speed work OK but fast doesn't- See video.
2008 Puma 110 DC.
Any ideas?
Thanks 👍🏻
[/s]
Post #943545 23rd Feb 2022 4:43pm
Guinness
When my park switch broke (52 TD5) the normal and fast settings worked fine, it was the intermittent and parking which failed. That is not to say that the park switch isnt broken for you, but might just have different symptoms but the same cause. It is a very cheap part to replace though if you want to diagnose through replacement. A bit of a faff to replace in a puma or 2002- TD5, you need to remove the majority of the dash.
Post #943548 23rd Feb 2022 5:07pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Getting to the wiper motor is a nightmare.
Post #943555 23rd Feb 2022 5:28pm
CalumD23
United Kingdom 2013 Defender 90 Puma 2.2 HT Tamar Blue
I’ve got a similar issue where they don’t park at the bottom of the windscreen unless it’s raining and they’re nice and slippery. It feels like the motor isn’t strong enough to push them down. Aside from constantly lubricating the windscreen who knows what to do…
Post #943561 23rd Feb 2022 5:56pm
Trendkill110
Calum - Exactly! If it's raining hard then they work fine however the fact that they don't go into 'Fast' mode and just intermittent or normal makes me wonder if its something more than just the park switch. They park fine if its been raining hard?!?
Post #943581 23rd Feb 2022 7:24pm
It is if you do it the way that those guys did, but it is wholly necessary to do that if you just want to change the wiper motor or the drive rack. It is a little more of a pain (literally) if you need to change the wheelboxes or the rigid tube, but even so you don't need to remove the dash completely.
There is a "how to" somewhere on the forum.
Post #943588 23rd Feb 2022 7:53pm
CalumD23
I might start with replacing the wipers, and a thorough scrub of the windscreen. But from everything else on here I think the motor might just be lacking and require a replacement.
Post #943609 23rd Feb 2022 9:28pm
