Home > In Car Electronics > Labcraft LED SCENELITE SI7 |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 |
I have them, No complaints.
Others had had corrision issues: See below: However customer service seems fit for purpose and all issues are resolved. https://www.defender2.net/forum/topic81644.html |
5th Feb 2022 4:11pm |
Drevil Member Since: 03 Jan 2022 Location: Berkshire Posts: 131 |
Interesting, I guess anything that is hung on the outside of a truck will pick up massive amounts of moisture and dirt and loss corrosion.
Are there any other interesting flush mounted work lights to consider, still think these are some of the best looking. |
5th Feb 2022 4:36pm |
Some people swear by the cheapy eBay ones.
I has an issue with DAB reception with cheap DRLs so fitted the labcraft. I also like the look.. |
5th Feb 2022 5:13pm |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 181 |
I've had one fitted for about four years now, no problems with it at all.
Click image to enlarge |
5th Feb 2022 6:56pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
Changed mine today after 4 years due to corrosion. Labcraft replaced the light no quibbles.
Click image to enlarge Click image to enlarge ORE 4x4 are very much worth looking at if Labcraft hadn’t replaced for free I would have brought from ORE 4x4 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
5th Feb 2022 7:03pm |
Bought an S19 in the end………let’s see how we get on once fitted.
8th Mar 2022 11:12pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
I'd be interested to hear what you think of it & any pictures.
9th Mar 2022 12:23pm |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 |
https://www.woodwayengineering.co.uk/produ...ene-light/
Got one of these this week. Not fitted it yet but the same as used on the appliances at work, and of all the issues that ensure the appliances end up in workshops it’s never the scenelights! |
12th Apr 2022 8:36pm |
Haven’t wired it in yet, but certainly looks cleaner than the previous unit
Click image to enlargei Was a bit anal and sought out some black hex bolts to go with it. |
7th May 2022 8:41pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
Let us know what it’s like once it’s wired in, I’ve been looking at this specific light and fitted it certainly looks good. 2014 Keswick Utility 2.2
7th May 2022 9:12pm |
Previous did look a little tacked on
Click image to enlarge Would’ve installed on the other side or centrally, but had to cover the old (huge) holes. |
7th May 2022 10:06pm |
All wired in and working. Super bright and does the trick.
8th May 2022 11:22pm |
