![]() | Home > General & Technical (L663) > FM v DAB+ v TuneIn preference |
Alicat Member Since: 25 Nov 2013 Location: Hertfordshire Posts: 136 ![]() ![]() |
Not used FM for years.
DAB seems to be better quality and the station I listen to is only on DAB. When DAB was less widespread reception would often switch back and forth between DAB and FM as signal strength changed. DAB always sounder better. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2717 ![]() ![]() |
Here it’s FM or nothing. No DAB coverage outside of major towns and the TuneIn relies on the car’s cellular connection which comes and goes as you go from glen to glen. My phone has much better coverage and streaming Spotify from that works well enough, the occasional buffering pause in poor signal areas.
I can never tell the difference between quality on FM compared to DAB or anything else. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3450 ![]() ![]() |
I usually use DAB, no reason why or music from my phone. 24MY 90 D250 HSE, Tasman Blue
