Home > In Car Electronics > Heated Windscreen Issues
MIGZ
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Evening all,
Was wondering if I could get some advice/guidance regarding my heated windscreen.
Two weeks ago when we had some v/cold weather noticed my heated windscreen had stopped working. On initial inspection all looks fine- no breakages in the screen, no fuses broken all looks ok...
So started looking deeper with a multi meter, across the screen it's measuring 3000ohms (which admittedly I think is an awful lot) and when power supplied 14V with 0.02A.
It's also an aftermarket screen (NordGlass) which probably doesn't help the situation. The connectors don't look rather robust either.
Has anyone had similar issues? Any easy solutions?
Thank you in advance! Smile
Post #939654 26th Jan 2022 10:05pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
As I'm here looking for advice on how to fit my wiring loom for my new heated screen, thought I'd pop and check resistance on my brand new screen and it is showing 5 ohms... at a guess you have a very poor connection somewhere.
Can't tell you what my current draw is as I haven't got it powered yet.
Post #945169 9th Mar 2022 4:45pm
