![]() | Home > General & Technical (L663) > Does a MY2022 need a module to use the Activity Key? |
graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 79 ![]() ![]() |
Thanks for that. It's all starting to make more sense now. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Ok, final update if anyone is interested.
Regardless of what it says in the Accessory Brochure (typical Landrover) a MY22 may or may not require a new KVM as well as the Key. According to Landrover Tech it should come out the factory locked as a security precaution so you cannot add any more keys. However, some vehicles may be delivered with space for the third key. It is unlikely though and the only way to check is to take it to the dealer so they can put it on the Pathfinder system and have a look. If you are lucky then all you need is the Activity Key, if not you need a new KVM as well as the key. The KVM is only around the £170 mark so it's not a deal breaker but my dealer is quoting an extortionate price to fit it. It's all pretty academic at the moment as the keys are almost impossible to get hold of! Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
