Home > Off Topic > Ethernet/Network switch - which one?
Pat
Wales
Is anyone able to recommend an 8 port switch for home use?
As part of a house renovation I have hard wired cat cable to several points and would now like to install a switch, but there are so many on the market it's not an easy job figuring out the best tool for the job. Advice would be appreciated.
I hope to keep things simple and don't really need anything high end or too complex. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now?
It's not a car, it's a way of life!
Post #939111 23rd Jan 2022 10:09pm
PCM
Netgear gs108.
Just bullet proof, install and forget gigabit switch.
Under £30
Post #939117 23rd Jan 2022 11:39pm
AMBxx
I'm not a fan of netgear. My 8 port netgear is now a 6 port for some unknown reason. The Netgear wifi access point only lasted 2 years.
Take a look at Draytek Vigor G1080 or similar.
Bit more expensive, but more like a proper business switch. It's a proper managed switch rather than a glorified hub. Allows for traffic priority etc.
Post #939128 24th Jan 2022 6:09am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I just brought a udm pro se (dream machine) has a 8 port Poe switch built in, and also 2.5gb uplink and two 10gb connectors so I can expand if needed.
It’s not cheep but looks to be simple to use, already have a access point from them that works seamlessly Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #939137 24th Jan 2022 8:45am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I've just added a TP-Link TL-SG1008P 8-Port 4-Port PoE Gigabit Ethernet Switch to my network because I intend to add some PoE CCTV cameras. It replaced an old 5 way 10/100 switch and has allowed my wired devices to take full advantage of the 300M fibre broadband that BT brought to my village recently Cool
Post #939146 24th Jan 2022 9:41am
Philm
PCM wrote:
Netgear gs108.
Under £30
I have been running one of these for years without any problems.
Post #939160 24th Jan 2022 10:34am
AMBxx
Looks like we've recommended the full range of price options! £30, £90, £300. Anyone higher suggestions?
Don't forget, OP, there's a huge difference between a managed and an unmanaged switch. Unmanaged isn't much better than a hub if you have a lot of stuff connected.
Post #939169 24th Jan 2022 11:01am
Dinnu
I use blackbox. Cant fault it. Ugly but rugged.
https://www.blackbox.co.uk/gb-gb/1499/Switches 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #939176 24th Jan 2022 11:27am
Cisco Catalyst 2960L-8PS-LL at around £700 ?
Well, you did ask.... Very Happy
Post #939180 24th Jan 2022 11:39am
Pat
Wales
Thanks guys, - but am I any the wiser?
I really don't think I need anything high end, the gamers have grown up and gone and no one is zooming from home. Only hard wired because circumstances allowed, no carpets, floorboards up, etc.. Current demand is, a desktop, a couple of smart TVs and a little smart lighting. Don't really need an 8 port, but just future proofing.
I don't have any networking background and this is my first attempt at setting up a home network.
Does managed offer much advantage over unmanaged for my needs? It started with a kiss, never thought it would come to this.
Post #939221 24th Jan 2022 2:17pm
Race.it
The simple option would be buy the cheep one and start with that then if needs move on maybe you connect some Poe stuff and need a different type of hub, or you want some cameras that auto record to a dvr, etc Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #939222 24th Jan 2022 2:31pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
I have done the same for working from home. I've been running 2 of these for a few years now. One in my office for NAS, Access Point, Laptops etc. and one in the TV room for TV/AMP/SKY etc. I can't fault them.
https://www.cisco.com/c/en/us/support/swit...model.html
Post #939233 24th Jan 2022 4:35pm
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
A 5 or 8 port unmanaged network switch like the one mentioned earlier will be perfect for you.
Post #939247 24th Jan 2022 5:47pm
AMBxx
Depends upon your broadband speed. If you're on gigabit, then won't matter. We get about 25Mb and can only upload at 1Mb. If I max out the upload, everything stops.
By having a managed switch, I'm able to prioritise the traffic to make sure streaming works while downloads take a back seat.
Start off cheap (it will do as a spare), then see how you get on.
Important thing is to do the network ports properly. Don't just have a cable hanging out of a wall.
Post #939356 25th Jan 2022 9:02am
Bluest
I’ve had a cheap Netgear unmanaged hub thingy for years with no problem. However, whilst I’ve stuff connected to all the ports I’m only really ever using one device at a time so didn’t see any point in managed. 2007 110 TDCi Station Wagon XS
Post #939361 25th Jan 2022 9:19am
