Home > Puma (Tdci) > Puma 2.2 front driving lights is there a connector on loom? |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
No…
And, No… 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
12th Jan 2022 8:38pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
there is however a LR auxlight loom and switch available that makes life simple to install driving lights, or at least there was for the 2.4 as I used it for my spot lights
and loads of aftermarket ones https://www.defender2.net/forum/post645026.html https://www.google.co.uk/url?sa=t&rct=...I6jlRtioKA https://www.mobilecentre.co.uk/defender-au...htbar-loom DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
12th Jan 2022 9:44pm |
If contacted duck worth parts vie PM or email defender2..net discounts are available
https://www.duckworthparts.co.uk/landrover...itlr006815 I used Robin.Hall@duckworth.co.uk |
13th Jan 2022 10:17am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2290 |
Any idea of a part number for this? Can't find it on lrworkshop > 110 XS Double Cab |
13th Jan 2022 11:08am |
Have searched the net myself and cant find it as a separate item, I got mine off ebay years ago so it could have been part of the full kit.
Below is a link to the kit and the instructions for fitting it. https://www.lrworkshop.com/parts/LR006815 I would add in LR fashion the cable ratings were the minimum required for 2 x 55W lamps, if I were to do it again I would buy an after market version with larger cable sizing less volt drop and bigger Wattage lamps. Will go have a rummage in my bits box just in case I still have the packaging with a part number but frankly unlikely as I did my lights probably 9yrs ago DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
13th Jan 2022 5:24pm |
