- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
![](templates/vbnew/images/breadcrumblogo.gif) |
Home > Off Topic > Petition against Greater Manchester clean air zone. |
Gareth
![](templates/vbnew/images/spacer.gif)
Petition against Greater Manchester clean air zone. | |
Over the next couple of years, if you drive a commercial vehicle, van, bus, taxi, campervan, or any vehicle including Land Rover Defender registered as commercial, that is Euro 6, your going to be hit with a daily use charge.
The area is the entire Greater Manchester area! Right into the leafy bits around the edge!
https://www.change.org/p/to-stop-mancheste...air-charge 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
10th Jan 2022 1:25pm |
Chugga90
I think there is already one on this subject running from Friday or weekend? Presume your item will be merged with that one?
10th Jan 2022 1:56pm |
