Home > Tdi > Fuel pipes/hoses too short...
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
Since having a 200tdi installed in my Ninety, the fuel filter housing has been mounted on a makeshift bracket, bolted to the bulkhead.
I'd like to replace the existing pipes (see below) with longer ones, but I'm struggling to find a supplier! Does anyone know where I can source said pipework in free lengths, so I can bend and cut to size?
Thanks!
Post #936649 6th Jan 2022 9:02pm
Mo Murphy
Replace it with 6mm id rubber fuel hose and clips. It doesn't have to be nylon pipe. Get it from any motor factors.
50 Shades of Pennine Grey
Post #936650 6th Jan 2022 9:07pm
landy andy
I think is just 3/8 plastic fuel line that you shape with heat, and use barbed fittings.
Like this sort of thing.
Post #936651 6th Jan 2022 9:12pm
Woody3
Thanks chaps! I'll get some ordered!
Post #936677 7th Jan 2022 9:13am
Dinnu
I was looking at fuel pipes on Paddocks site, and they seem to be able to supply a few (special order), looking very similar to the original plastic pipes - my originals still look like new.. but my new lift pump has ports on the top side instead of the sides. I ended up ordering a lift pump with the ports on the sides. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #936678 7th Jan 2022 9:34am
