Home > Puma (Tdci) > Need help with hill starts with anti-stalls
fatduckling
Australia
Hi
I have a 2011 Defender 110 which I use as my main vehicle 1-2 times a week. It's my first car and I don't do any off-roading with it. I've been driving it for a year, and have had no issues with hill climbs because the car has lot of torque in first gear and the roads are fairly flat around my area in Sydney.
However, I was driving through a country town and I came across a most steep hill. I had to climb up slowly in 1st gear as there was cars ahead of me. When I had to do a hill start at the end of the road, I struggled as the car rolled back about half a meter before going forward. Thankfully, no cars were behind me!
The technique I used when it was my turn to go:
1. Foot on brake and in neutral position
2. Depressed clutched and moved to 1st gear
3. Slowly released clutched to biting spot
4. Removed foot off brake and pressed accelerator slowly
5. Car started rolling back, so I panicked and gave more throttle and released clutch
6. I can hear the wheels skid, but managed to get going
It was a bit of a scary feeling as this is my first manual car and I didn't ever drive on a hill as steep as this.
I can't use the handbrake method because my handbrake is not really strong (I think it's a defender thing?), so even if engaged the handbrake, the vehicle would still rollback.
After reading online in other posts, I can see other defender drivers use the anti-stall feature when they go off-roading up steep hills, so I want to learn how to do do this in my vehicle for hill starts.
If my reading is correct, I have to use the transfer gearbox to move to low range position and then it shouldn't stall when taking off in first gear right? Then I can move to 2nd/3rd gear in the main gearbox (while still in low range in transfer gear) until I have enough speed to then switch to high range in the transfer gearbox right? The manual says to leave the transfer gear in neutral for 3 seconds before switching to high range.
From the manual, I can see:
Quote:
Stationary method
With the vehicle stationary and the engine
running:
1. Depress the clutch.
2. Move the transfer lever from the current
range setting into the neutral position (e.g.
from high to neutral).
3. Move the transfer lever from neutral into
the desired range setting (e.g. from neutral
to low).
Changing from low to high on the move
1. Apply slight rearward pressure to the
transfer lever, in preparation for the range
change.
2. Then, in three simultaneous moves,
depress the clutch, release the accelerator
and pull the transfer lever into neutral.
3. Release the clutch pedal for approximately
three seconds, before pressing it again and
moving the lever firmly into the high range
position.
4. Select a suitable main gear in the main
gearbox, release the clutch and continue
driving as normal
For the entire time I owned the defender, I have never used the transfer gearbox (always was on high range) as I never needed it, so I was wondering if you can please provide any advice or tips on how I can conquer extreme hill starts using the anti-stall feature. I have used the handbrakes for very steep hills in other manual cars, but doing it on a defender seems much more difficult. I'll go in an empty parking lot to practice in the new year.
Thanks in advance <3
Post #935714 31st Dec 2021 5:28am
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
It sounds like you might need to get your handbrake adjusted.
https://www.defender2.net/forum/post134568.html
Once adjusted start practicing your hill starts, as it's a transmission brake it takes some getting used to taking up the backlash before releasing the handbrake.
As for switching between Hi and Lo follow the method and again practice on flat ground. I double clutch at neutral point, I find it makes for a smoother change.
Post #935715 31st Dec 2021 6:07am
Dinnu
Never change transfer box ratio at speed. There should be a decal in the dash and Landrover suggest to only change transfer box ratio between 0 and 5mph. I think 5mph is too fast. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #935716 31st Dec 2021 6:29am
Co1
I don’t use the handbrake on any gradient of hill, I use the technique you describe. You might just need more practice, and I’d suggest start on flat ground to get your confidence up.
Agree with Dinnu re the transfer box change. Do it stationary.
Post #935725 31st Dec 2021 8:44am
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
Does the anti stall only work in low range?
Post #935734 31st Dec 2021 10:49am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
No, anti-stall works in high range too.
I'm currently living on a farm and the speed that the anti-stall gives in 2nd (high ratio), is about perfect for chugging about.
Post #935735 31st Dec 2021 10:56am
Re: Need help with hill starts with anti-stalls
No, it works in high range too but it's not infallible and shouldn't really be used as a substitute for proper clutch control.
Firstly, as already noted above, get your handbrake adjusted if it won't hold the vehicle on a hill. Whilst the mechanism is different to ordinary cars, acting on the transmission rather than the back wheels, it's not 'a Defender thing' for it not to work in the circumstances you describe.
To be honest, it just sounds like you need more practice doing hill starts. Your technique up to no.4 sounds fine but at that point you need to progressively balance letting the clutch out with applying the accelerator. It's not different from any other car but the clutch pedal may be heavier than you're used to. It's easy to write this, of course, but there's really no substitute for trying it out until you've got a better feel for it.
Whilst using low range to start on a steep hill is a legitimate technique, it should really only be necessary on tarmac if very heavily loaded or towing a large trailer, for instance. The subsequent technique of changing from low to high on the move is not for the feint hearted and is much more tricky to get right than a practiced hill start. Darren
Post #935737 31st Dec 2021 11:05am
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
In my opinion anti-stall on tdci is excellent and more than capable of making hill starts in high 1st. except on the very steepest hills.
Whilst holding the vehicle with the footbrake select first gear, bring the clutch up to the biting point and then slowly release the brake pedal, simultaneously letting the the clutch all the way up. The anti-stall will do exactly what it says on the tin and fuel the engine to move away at idle r.p.m. Once moving feed in the throttle.
Worth bearing in mind that as soon as there is throttle input anti stall is overridden 2011 130 Utility Body
2005 110 Van
Post #935752 31st Dec 2021 1:02pm
landy andy
As some above I don’t use the “hand brake” for hill starts, it’s not for that in my opinion it’s a park brake, especially on a Defender where it’s a transmission brake. You just need to practice the art of hill starts from what I understand from your post. Either gentle release of clutch using the anti stall, or using power but not too much. I’m thinking perhaps you just gave it too much power so were spinning the wheels. Another point I would add, is that you need to use your high/low and diff lock on/off so these things don’t seize and cause issues for you later.
I’d advise finding a big, but quiet hill and getting some practice done. The better you get the longer your clutch will last. So stay away from loads of revs.
Post #935756 31st Dec 2021 1:30pm
Bluest
As above I use the anti-stall to pull away on gradients I usually get rolling with no throttle pedal at all, just bring the clutch up, release the brakeand then accelerate away once off the clutch. 2007 110 TDCi Station Wagon XS
Post #935757 31st Dec 2021 1:39pm
fatduckling
Australia
Thanks everyone for your responses!
I think it boils down to two things:
1. I need more practice with hill starts so I'll work on this
2. Get my handbrake adjusted so it can hold itself on a hill.
Also, how does the anti-stall work? I have the transfer gear in high range and main gear in 1st, and if I remove my foot off the clutch, it still stalls. I have a 2011 Defender 110, so do I need to set the transfer gear in low range for the anti-stall to work?
Post #935770 31st Dec 2021 4:15pm
Bluest
It’s a gradual thing. As you slowly release the clutch and give some load to the engine the ECU increases the “throttle” automatically to prevent a stall. Of course you can still stall it if there’s too much load (maybe a big trailer on a steep hill) or just sidestep off the clutch, but the TDCi has a lot of torque at idle so it’s shouldn’t stall easily at all. 2007 110 TDCi Station Wagon XS
Post #935774 31st Dec 2021 4:33pm
Trundlebus
I well be told I do it wrong but: my puma is used with a demountable camper. When fully loaded it is 3500kg. We frequently go into mountains. When I have to start on a steep hill I stop the engine, engage low range (if it’s really steep). Put it into gear. Hold it on the foot brake, start the engine and let go of the brake. I do not touch the clutch. The truck just drives up the hill. Change gear as normal once underway
Post #935786 31st Dec 2021 6:34pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I love hill starts since getting my puma. Hill starts are quite possibly my favourite thing. I never use the hand brake when driving, its just a parking brake. Technique: Hold the vehicle on the foot brake, bring up the clutch gently, only release the foot brake gently when you feel the engine pushing against the brakes. Take your time moving your foot to the accelerator, the anti-stall is amazing so there's no rush. Anti-stall is a thing of beauty & creates the calmest of hill start experiences, however laden the vehicle. My tip would be to relax into it, almost to the point of sleeping, & experience the full joy of a calm slow-motion hill start. The defender will take care of itself. Forget what you've learned to do in lesser vehicles.
Post #935799 31st Dec 2021 8:16pm
I won't say you are wrong, but I do wonder at the additional stress on the starter motor. You can move the vehicle with the starter motor but I've only used that on the flat and in an emergency.
Also if the vehicle is in gear before you start the engine, I would have thought that made use of the footbrake redundant?
Post #935852 1st Jan 2022 11:28am
