Home > Series Land Rovers > Series brake cylinder problem
Page 2 of 2 <12
seriesonenut
So for completeness - now fixed.
I clamped the brake hose, removed the bleed screw completely then with a G clamp pushed the pistons back into the closed position.
At that point if the G clamp was removed they sprang back out. Tried again and this time whist clamped put back the bleed screwed tight. The pistons remained closed , released the hose and then was able to re fit the drum as expected.
So it seems no air in the empty brake cylinder was the answer!
Just a footnote in case anyone else has a similar experience. 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #937669 14th Jan 2022 9:32am
Page 2 of 2 <12
