Home > Td5 > knock in steering column over rough roads |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Open the bonnet and get a mate to turn the steering wheel left and right without the engine running. Doesn't need to be big movements, just small.
While they do that, check the steering system for anything that it shouldn't be doing. Even if it happens only while driving on the rough, there should be some clue. |
11th Sep 2011 2:05pm |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 |
Drop arm ball joint will probably be the culprit. Just make sure you get a decent one (I always buy genuine) and get whoever replaces it to replace ALL the parts and not just the ball itself as the cup at the bottom is what wears the most.
11th Sep 2011 3:22pm |
paullo Member Since: 14 Dec 2010 Location: Just Outside the M25 Posts: 47 |
Cheers for the responses
I'll have a look this weekend and go from there. Thanks. |
13th Sep 2011 1:13pm |
