Home > General & Technical (L663) > V8 gear shifts
lazurus
V8 gear shifts
Anyone notice that the gear shifts higher up the rev range (red line) the harder you press the throttle, even in comfort mode? I find this a bit weird, understand it in dynamic mode but didn’t expect the rpm gear shift trigger to change dependent on the weight applied to the gas pedal.[/img]
Post #933174 11th Dec 2021 9:12am
Cheshire110
That’s how every automatic I’ve ever driven behaves really…
With a modern auto you really have to think of the throttle pedal as more of a “power” pedal rather than anything simply throttle-connected. More power needs (often quite a bit) more rpm in a petrol engine in particular.
That being said exactly how it’s calibrated does make a difference to the feel. Our diesel Land Cruiser 200 revs its nuts off unnecessarily whereas I remember our disco 4 used to always just trickle along in as low a gear as possible pretty much.
Haven’t driven a P525 but my p400e defender, when you get the engine engaged is very rev-happy too. I guess Land Rover think that people like the sound of the V8! Cheers, David
Post #933175 11th Dec 2021 9:37am
Herdwick
Cant say I have noticed it at all, drives just as I would have expected.
(Maybe I am not trying hard enough), just coming up to 1k miles in mine.
Post #933180 11th Dec 2021 10:57am
lazurus
Yes it’s odd, most cars I have driven the pressure applied to the gas pedal didn’t change the gear change rpm unless a given mode is selected. But in comfort mode I wasn’t expecting it to go “well if you apply quarter peddle I will change at 3000rpm but if you apply full peddle I will change at 7000rpm”. Seems excessively “revvy” to me in a mode that I would have thought to be more relaxed.
Post #933299 12th Dec 2021 4:47pm
