Home > Puma (Tdci) > Puma 2.2 Tdci Aircon fun and games |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2101 |
I had a similar issue when the gas was added it all looked good but when the engine was running and I went for a drive the gas leaked away
so my suggestion is to get the system charged with dye and then run the engine so as you may be able to detect the leak then I have had to replace the condenser as the leak was there and that was not a cheap part, however it was an easy job to do so only had to pay for the re-test and re-gassing - been fine since then Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
5th Dec 2021 10:22pm |
Portafilter Member Since: 08 Aug 2010 Location: Melbourne Posts: 27 |
my 2.4 did same and turned out it was condensor inlet (i think) out front of the radiator! workshop commented that had never seen it leak there before..
7th Dec 2021 5:44am |
