![]() | Home > P400e Area (L663) > Preconditioning/Schedule/PodPoint - what am I doing wrong! |
hezor Member Since: 01 Feb 2021 Location: Nurmijärvi Posts: 53 ![]() ![]() |
I have a P400e with OS3.0.0 software. OS3 completely revamped the EV screens including setting charge periods.
I normally use "Immediate Charging". But I have tried "Smart Charging" and "Low-Cost Charging" options, and in my case they do not work at all. When Smart Charging or Low-Cost Charging is selected (and the low cost time period has been set AND departure time has been set) and after the car is plugged in, it shows "TIMED CHARGING" in the dash and in the LR Remote app. But the issue is that the car is in that state forever - it never starts charging. It might be a bug in the software, or my car is acting up. I'd like to get this working, as with this feature the battery could be charged during night time, which means the battery is still warm in the morning when I leave for work. This is important as it's -20C outside in Finland right now, so not much EV driving happening with a freezing battery. 22MY Defender 110 P400e SE w/ Off-Road Pack, Driver Assist Pack, Cold Climate Pack, Comfort & Convenience Pack + ClearSight Rear-View Mirror & 11.4" Infotainment Screen |
Rhywle Member Since: 02 Dec 2021 Location: Y Bont Faen Posts: 5 ![]() ![]() |
Thanks Hezor
It's good to know it's not just me that finds it unreliable. I thought it would be as simple as "set the times and charging will happen during the lower cost times!" I don't have OS3.0 yet - new so waiting for the SOTA. It may be that will help. I did find a workaround - that's worked once so far - by setting longer hours on the wall charger and then setting a timed charge on Defender. It seemed to work although the Remote app reported that Defender was sat 'initialising' for hours before the wall charger let it have power. But it worked. Be interesting to see if OS3.0 makes any difference but it doesn't sound like it will. ![]() |
NJSS Member Since: 26 Aug 2014 Location: Catherington Posts: 31 ![]() ![]() |
Has this yet been resolved ?
NJSS 2016 Discovery 4 Landmark 2011 Mercedes Benz SL350 (R230) 1973 MG B GT V8 - 3.9L John Eales engine, 5 speed R380 gearbox, since 1975. 1959 MGA roadster - 1.9L Peter Burgess Engine - 5 speed gearbox Past LRs - Multiple FFRs, Discos & a Series I - some petrol, some diesel, none Electric yet. There are 10 types of people in this world: Those who understand binary, and those who don’t. |
D50 Member Since: 08 Apr 2021 Location: Dublin Posts: 20 ![]() ![]() |
Hi all,
I don't know if anyone has got to the bottom of this. I finally got a charger installed today for my P400e so trying to figure all this out! I don't appear to have the "Smart" "low cost "or "Timed" charging menu options as referenced below....im running OS 3.2.1. MY23 model. If I want to set specific time periods I have to go into settings and then preconditioning and theres an option to set charging windows, I've been trying to set it for a 3 hour period between 2am and 5am at night to avail of an EV tariff but it just starts charging when its plugged in.... Thanks |
Jonas Member Since: 17 Aug 2023 Location: Stockholm Posts: 2 ![]() ![]() |
Hi!
Just bought a Defender P400e 110 Dynamic HSE in Carpathian Grey. First Land Rover (driven BMW for the last 12 years9 and I absolutely love it! When charging at home (have a 11 kw callbox) I try to set the charging between 1 - 5 am yesterday (cheaper price) and leaving time in 7 am. As soon as I plug in the cable it starts to charge! Never had a problem like above with our BMW I3s. Read the guide yesterday and it says I should have an app in pivi called "vehicles departure time" but I can't find it. Very grateful for feedback and solutions. Thanks! /Jonas |
Hi Jonas,
I have found that the manuals don't completely relate to the EV parts of the car. I've tried to outline the process that works for me. Select "EV" from the Menu ![]() Click image to enlarge Then select Charging and select the days you want to set up pre conditioning / departure times for ![]() Click image to enlarge Then input the preferred departure time ![]() Click image to enlarge On the next screen make sure you have selected "Smart Charging", you can then input your low cost hours (it should save these going forward) ![]() Click image to enlarge Finally, when you turn off the car, it will prompt you to charge now or delay to the low cost hours and departure time ![]() Click image to enlarge |
Thanks for your reply, very appreciated!
Tried to follow your steps, but after I made the settings in the car and then turned it off an connect the cable the wallbox starts to flash blue (witch means waiting to charge) but after a few minutes the wallbox a firm blue light witch means it charging and the car starts to charge when I go in to the Remote app. Very strange i also checked updates of the pivi software and it says it was updated 7 august 2023 so it should be up to date I guess. |
Biffyg Member Since: 29 Feb 2024 Location: Liverpool Posts: 38 ![]() ![]() |
Has anyone got low cost hours to work? set mine up to charge overnight for my new low cost tariff and came out to an empty battery this morning. 24MY 110 p400e HSE in Tasman Blue
jimjamken Member Since: 01 Mar 2023 Location: Surrey Posts: 90 ![]() ![]() |
Did you set a departure time on the SMART charging screen? It only works if you do.
ah right, do i need to set them for the weekend as well then? 24MY 110 p400e HSE in Tasman Blue
I tend to set them the night before for the following day but I think you can set multiple days departure times in the car
I've just added random early ones for Saturday and Sunday with no climate. Let's see if that works 24MY 110 p400e HSE in Tasman Blue
That worked, thanks 24MY 110 p400e HSE in Tasman Blue
nobbyclark Member Since: 19 Jan 2011 Location: Cumbria Posts: 56 ![]() ![]() ![]() |
I haven't tried smart charging in my P400 yet as my provider, Ovo, do not recognise LR in their app. I did play around with it on my previous car, a P400 Range Rover, and it seemed very hit and miss as to whether it would actually charge in the off-peak time period. Usually a miss. Not that it makes any difference when the tariff is the same all day.
