Home > Puma (Tdci) > Simple CTEK charger question. |
Bear in mind that the standard lighter socket isn't live unless the ignition is switched on, so is no good for charging. Darren
6th Dec 2021 9:35pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
As LRA + nitram17 say... 'we' are sure that your Puma Julie will not have a permanent live standard cigarette lighter (or cigar... ) picking up on the rear permanent live and installing an additional socket/s could be the way to go... Click image to enlarge https://www.defender2.net/forum/topic20319...anent+live SKIP https://www.defender2.net/forum/topic83242.html |
7th Dec 2021 9:50am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 498 |
2x permanent live for the différent batteries in the front for charging and heavy consumers (cooling box)
& in the rear only permanent life from service battery (living comfy |
8th Dec 2021 7:57pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Mine are all looked after via a Cetek, The 110, with one of the above in the MSS cubby box,, simple California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
8th Dec 2021 10:33pm |
