Home > Tdi > Leaky injectors 200tdi |
You could try to nip them down a little to keep going. Have a look regardless and check the securing nut hasn't become loose or the clamp hasn't banana'd...
But in the longterm yes you need to replace the copper washers. |
28th Nov 2021 10:02am |
anneal the copper washer and or get new set
28th Nov 2021 10:58am |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 932 |
Given that a set of washers is less than a fiver it does make sense to replace. I have ordered some.
In the meantime, the only one I could get a socket to was number 1 so I checked the torque and it was a fair bit below the recommended 18 ft-lb. I have nipped them all up a little and cleaned up around. I'll take it for a spin and see how it is. Thanks for the replies |
28th Nov 2021 11:42am |
Set about replacing the washers this morning only to find that the banjo on the fuel return on number 1 injector was loose. Very loose.
Took the injector out, cleaned it and replaced with a new washer and then ensured the banjo was tightened. On checking the others, although not loose, they were not tight. All nipped up now and seems OK. |
4th Dec 2021 11:36pm |
