Home > Maintenance & Modifications > STC1346 - Vent
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
STC1346 - Vent
Help needed I want to put 2 vents in the roof at the back above the rear door and just wondering if these are the vents I would need STC1346 - Vent . Most have them either side of the rear door wash jet if not could anyone point me in the right direction as the back is full condensation with the weather changing.
Post #930047 16th Nov 2021 10:53pm
kaney
Post #930050 16th Nov 2021 11:04pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Yep, they are the 'factory' ones. Hopefully someone can advise you on the correct position to mount them. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #930054 17th Nov 2021 5:40am
kaney
Thanks Shroppy
Much appreciated I will order them this week just did not want to waste £82.00 with the postage
Post #930062 17th Nov 2021 8:01am
kaney
Ordered 2 there's 3 left i think if anyone else is after any see link in previous message.
Post #930149 17th Nov 2021 8:04pm
kaney
Post #930153 17th Nov 2021 8:20pm
Litch
Weren't they the same part as fitted to Austin Maestro vans?
Seem to recall that they were deleted after a few years as they were prone to allowing water in.
Having lived with an unlined hardtop I have to admit condensation is not a lot of fun but a headlining cures it completely. If you want a pure utility however then ventilation should help. ONE LIFE, GET IT!
Post #930291 18th Nov 2021 8:41pm
kaney
Laughing Laughing prone to allowing water in. That bit made me laugh as being in a Defender you would think condensation would not be an issue. whist searching about the vents on here I found an older post mentioning the Maestro.
My issue is wet tools and clothing being in the back from work and no heated window in the back door it soon fogs up which then would cause the headliner and other material to start to get mould on
Post #930297 18th Nov 2021 8:51pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Hi. I've got these vents in my '89 90. Did you want measurements of their position or are you just going to bosh them in? Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #930351 19th Nov 2021 1:19pm
kaney
Thanks I would love to have the measurements as trying to get most stuff looking as Land rover had done it
Post #930353 19th Nov 2021 1:30pm
L90Andy
This is the RH one, measured down from the top of the roof and along from the roof seam. HTH
 Instagram: L90andy
Post #930361 19th Nov 2021 2:11pm
kaney
That's great Andy much appreciated I will see how it goes with my decals on either side and get the vents as close as possible
Post #930363 19th Nov 2021 2:24pm
L90Andy
No probs. They should be ok, the vents are only above the door section Thumbs Up
 Instagram: L90andy
Post #930365 19th Nov 2021 2:28pm
kaney
Thanks again I will use your pictures for reference
Post #930373 19th Nov 2021 3:11pm
I filled mine in with mastic..... back of the 110 kept getting full of dust being sucked in.
Post #930580 21st Nov 2021 12:24pm
