Home > Modifications & Maintenance (L663) > Missing centre console solution |
coastal16 Member Since: 28 Jul 2021 Location: yorkshire Posts: 2 |
[/code]When I took delivery of my 90HT, they had failed to fit the centre console I had specced and refused to retrofit one.
After several weeks of dialogue with the dealer they agreed on a smallish cash "softener", some of which I used to purchase an Alpicool 15lt 12/240v fridge with. Power was taken from the front 12v connector: a fused cable chased under the rubber flooring through to a panel fitted to the panel behind the drivers seat. Tray removed and a block of worktop cut to size, this was covered in neoprene and a small 90 bracket screwed front and back to prevent fridge from sliding around. I'm happy with the result as more than anything needed an armrest. Fridge has an auto cutout if battery level falls below a certain level. Might help someone who is in the same situation. https://ibb.co/k0p206v https://ibb.co/W2Px74C https://ibb.co/7KLnVLz https://ibb.co/V2h13W7 |
14th Nov 2021 12:01am |
